[Vous devez être inscrit et connecté pour voir ce lien]-AGM 30cc Gas Engine is a new alternate choice of engine producing high power for use in many kinds of 30cc RC Model airplane.
-T-he CDI Module of AGM uses good quality integrated components and offers a wide voltage input range to ensure reliable ignition performance with perfectly timed spark across the entire engine rev range for smooth throttle control and a super stable idle. Original Walbro Carb instead of OEM one.
-If you were perhaps considering DLE30 or similar engines for your next ARF build then first be sure to check out what you could do with the new AGM30!
