 TURBINE 250 FPV RACER
MessageSujet: TURBINE 250 FPV RACER   Sam 06 Juin 2015, 09:09
J'sais pas si vous connaissez ?
J'l'ai eu en main, et sous réserve, c'est d'la bête !
250 roros en bnf Wink
e-TURBINE 250 FPV racer quadcopter is a small size Multicopter made for racing and funfly!This combo including the Lipo battery, Camera, Video tx 25mw with cloverleaf/ Spyro Antenna for increased range
In general FPV racing,Drone is equiped with a front looking camera and with a real-time broadcast system, so the pilot can watch the pictures with video goggles. In a forest, or on artificial obstacle courses, high speed FPV flying is a challenge when you fly alone, and became very addictive when you practice racing with other modelers. Remember the famous pursuit on the moon of Endor, in the forest, in Star Wars movie. That's what you can expect ! Spare propellers must be expected, but quad racers are very strong and withstand the crashes against obstacles, ground or other competitors models...
This quadracer is delivered as a combo, see below what is included.
The four 2204 brushless motors and four 12A ESCs are included, and you will also find the CC3D flight controler. Two high intensity 3W front LEDs will be usefull to fly in the dark, and a rear LEDs strap will help your colleagues  to see you and to avoid a contact.
Just Add radio, and your own charger, or get one from us and you ready to go.
Specifications:
   Dimensions : 250 size machine
    Flight time : 8 - 13 min
    Weight incl. controller, no lipo- 403 gr
Included in the set:
•Motors : 4 x TB2204
•ESCs : 4 x 12A
•Propellers : 4 props 5 x 3"
•Flight contoller:CC3D
•Lipo pack 3s 1300 - 1350
•FPV camera 600+TVL
•Video TX 25mw
•Cloverleaf-Spyro TX Antenna
•Front LEDs : 2 x 3W white
•Tail light : 140 mm LEDs strip. Steady and 5 flashing modes. 8 intensity levels.
Xyphon
MessageSujet: Re: TURBINE 250 FPV RACER   Sam 06 Juin 2015, 10:39
Je l'avais repéré oui, il à l'air très sympa Smile
MessageSujet: Re: TURBINE 250 FPV RACER   Sam 06 Juin 2015, 13:34
Il est livré tout assemblé et la carte parametre ?
MessageSujet: Re: TURBINE 250 FPV RACER   Sam 06 Juin 2015, 13:48
tout à monter,
et pour la carte, je sais pas.
Gingko.j
MessageSujet: Re: TURBINE 250 FPV RACER   Sam 06 Juin 2015, 18:47
Oui je les vue aussi il a l air sympa avec camera deux led devant et une bare a l arriere chez mcm racing il est a 199 a monter et 259 assembler avec une valise de transport je trouve sa raisonable
» TURBINE 250 FPV RACER
» Speed Racer by Larry and Andy Wachowski
» Riley Racer & Slot it
» 1/72 Belly Tank Wacky Racer
» MERCEDES racer 1/16
